The sleep of LIN bus
guofeng
   After the master node send the frame (ID=0x3C: 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF),  the slave node should go to sleep. But, I don't know the LIN bus got the frame (ID=0x3C: 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF).
   Is there interface in the LIN Stack?  I am using the FSL_LIN_2.x_STACK_Package_4.5.9,  MCU is S12VR64.
Best regards.
dianabatrlova
Currently with FSL_LIN_2.x_STACK_Package_4.5.9 we don’t have interface to catch go_to_sleep frame, but you can use lin_lld_get_state() function to get state of LinStack node in state go_to_sleep or not.
For example:
if (lin_lld_get_state(LI0) == SLEEP_MODE) or
if (lin_lld_get_state() == SLEEP_MODE)
Diana
dianabatrlova
For example:
Diana
