I am using the XE100 with the -Ml large model
I have a large array unsigned char heap[heap] defined across 2 RAM segments, ie 8k byyes
using .prm with
RAM_F0 = NO_INIT 0xF01000'G TO 0xF11FFF'G;
HEAP_RAM INTO RAM_F0;
I use the declaration
#pragma DATA_SEG __GPAGE_SEG HEAP_RAM
unsigned char heap[ 8192 ];
#pragma DATA_SEG DEFAULT
This compiles but generates a linker warning L1408: Conversion of address of heap overflowed 0xF01000´G
However the .map file show the 0x2000 bytes to be allocated correctly at 0xF01000'G
The "What is this" information talks about excessive debug information. Is there a further flag that needs to be set in CodeWarrior v5 to debud global addressing?
解決済! 解決策の投稿を見る。
The top most global address is 0x7FFFFF'G.
So true. The global map 0x0F_FFFF'G - 64k = 0x0F000'G. Thanks prm was wrong
