S9S12ZVLS3F0VFMR and S9S12ZVLS3AVFMR Distinction
500 次查看
caesar_song
Dear All
    Woudly you kindly help to provide the  document of S9S12ZVLS3F0VFMR and S9S12ZVLS3AVFMR  different ,and the wafer lab explain,thanks.
标记 (1)
405 次查看
lama
S9S12ZVLS3 F0 V F MR
S9S12ZVLS3 A  V F MR
The F0 means mask set as well as letter A. There were two mask set with different number but the same and the difference was only manufacturing factory.
Because of this, NXP stopped distinguishing the part number in terms of place of manufacture and a new mask set label was invented ... “A”.
So mask set A is absolutely the same as mask set F0 which means mask 0N22G and corresponding errata list.
PCN 202103038F01  … Issue Date: Apr 17, 2021  Effective Date: Jul 16, 2021
Attached is a file from PCN which explains numbering (I explained above) at slide 5.
Ladislav
489 次查看
caesar_song
The PCN for S9S12ZVLS3F0VFMR and S9S12ZVLS3AVFMR
490 次查看
caesar_song
Would you  help to provide the PCN for S9S12ZVLS3F0VFMR to S9S12ZVLS3AVFMR,thanks
