S12X - EEE - Not applying RAM changes to NVM?
678件の閲覧回数
saschapfengler
Hi there!
I was reading this sentence in AN3490...
"If more data is written to the same EEE RAM location before previous data has been programmed to the
EEE NVM by the memory controller (because it was busy or the EEE is disabled), only the RAM contents
will be updated; the increment of the counter will remain valid from first data write to the EEE RAM."
...and was wondering if this meant, that changes in EEE RAM may not always be applied to D-Flash / EEE NVM.
As I understand this:
start
EEE-RAM content: 0xFFFF
EEE-NV content: 0xFFFF
write to EEE-RAM:
EEE-RAM content: 0x0000
-> Start of EEE-NV Write
EEE-NV content: 0x????
-> While EEE-NV Write in progress: Change to EEE-RAM content (No Write Counter increment?)
EEE-RAM content: 0x00AA
-> EEE-NV Write Operation finished (Write Counter decrement)
EEE-NV content: 0x0000
-> No new EEE-NV Write triggered automatically?
566件の閲覧回数
RadekS
Hi Sascha,
This is not that case.
“If more data is written to the same EEE RAM location before previous data has been programmed” means more than one write.
start
write to EEE-RAM:
write 0x00AA to EEE-RAM:
-> While EEE-NV Write in progress: New task is entered into queue. (Write Counter increment)
write 0x00BB to EEE-RAM:
-> While EEE-NV Write in progress: Since more than one data is written to the same EEE RAM location, new task is not entered into queue. (No Write Counter increment)
EEE-RAM content: 0x00BB
-> EEE-NV Write Operation finished (one task still in a queue)
EEE-NV content: 0x00BB
Note: there isn’t any direct mapping between EEE-RAM address and EEE-NV content address. The EEE-NV content is the last record with some ID (that refers to EEE-RAM address) in Active/Full sectors.
I hope it helps you.
Radek
2 返答(返信)
567件の閲覧回数
RadekS
Hi Sascha,
start
write to EEE-RAM:
Radek
566件の閲覧回数
saschapfengler
Thanks for your detailed answer, Radek Sekar!
This is what I was hoping for. ^^
