Problem with __far function pointer in S12XEP100
2,397 次查看
cs_Lukasz
In my project I use function pointers. Memory is banked. I dont use X-Gate
 typedef struct        {
  volatile        Byte            (*__far proc_pointer) (void);        // pointer do wykonania procedury
} pseq_pdat;
Byte            pseq_addproc        (Byte *name, void *__far pointer)    // dodanie procedury do kolejki
volatile    pseq_dat        *pseq_datx;
volatile    pseq_pdat       *pseq_pdatx;
pseq_pdatx[i].proc_pointer = (Byte (* __far) (void))pointer;
In code I use a function for ex:
pseq_addproc((Byte*)"SysLed Timer", &Tmr_SysLed);
In map file function Tmr_SysLed has address 0xFEA3E6. But when I run debug mode I see the pointer has address: 0xFE2B07. There are no functions at this address, but there is struct pseq_datx. I dont now why pointer points to bad address ;/
Best regard
Lukasz
628 次查看
cs_Lukasz
I find the solution:
- bad syntax:
- good syntax:
void (*__far FunPtr)(void)= Tmr_SysLed;
pseq_addproc((Byte*)"SysLed Timer", FunPtr);
4 回复数
628 次查看
cs_Lukasz
EDIT:
My code is small and is located only in PPAGE 0xFE so i'm not sure but propably i dont have to use far pointers. But when I executed function pointer pseq_pdatx[i].proc_pointer(); a PC jump to illegal address ;/
I forget earlier my code works well but on memory model large. When i'm usink memory model banked it dont work.
Message Edited by cs_Lukasz on 2009-07-06 02:25 PM
628 次查看
CompilerGuru
Not sure if this is you issue, but in the code I see a conversion from a __far data to a __far function pointer.
Note that those types of pointers are not compatible, you can start with a __far function pointer, cast it to a __far void pointer and cast it back, that ok.
But you cannot direcly use a data pointer to access the code the function pointer points to.
(or use a function pointer to execute the code a data pointer points to).
The reason is that __far data and __far function pointers are using a different byte ordering, see the compiler manual for details. Basically __far data pointers are big endian encoded, __far function pointer use a format so they are in memory usable by the HC12 CALL instruction.
I doubt a bit because the address you mention does not look like this is the issue you have. Just something which comes to mind when looking at __far function pointers.
Check if the function pseq_addproc is called with the right address or if the problem occurs in there.
(and, BTW, for the S12X, __far data pointer are using global addresses too).
628 次查看
cs_Lukasz
Thanks for reply!
Sometimes it is useful to read a documentation :smileyhappy:. Thath right my function pointer points to data not function.  So I modify my code like that:
Byte            pseq_addproc        (Byte *name, void * pointer)    // dodanie procedury do kolejki
pseq_pdatx[i].proc_pointer = FunPtr;
That works fine but I dont use input *pointer from function pseq_addproc but I openly write pointer to function Tmr_SysLed fo FunPtr and later to structure pseq_pdatx. I have no idea how write input pointer to structure instead od FunPtr like now.
In line
I have warning Pointer conversion: possible loss of data, so pointer is ony 16 bit wide ;/
Earlier I have no problem here because of using large memory model and pointer was always 23 bit wide.  When I modify function  like that:
pseq_addproc        (Byte *name, void *__far pointer),
pointer is 23 bit wide but points to bad address (page is wrong), for example:
Tmr_SysLed has address: a3d5FE
pointer points to:            a3d57F
Message Edited by cs_Lukasz on 2009-07-07 10:50 AM
629 次查看
cs_Lukasz
- bad syntax:
- good syntax:
