MM9Z1J638 switch to MM9Z1I638
已解决
跳至解决方案
1,881 次查看
Boris_Bloxsberg
I want to change my firmware from the MM9Z1J638 - Chip to the MM9Z1I638 chip.
Does somebody know points I have to change in the code? Where can i change the memory size?
1 解答
1,866 次查看
danielmartynek
Hi @Boris_Bloxsberg,
The difference is in the Flash size.
You can simply create a new project in CW 11.1 for the MM9Z1I638 part, copy your code and compile it.
在原帖中查看解决方案
5 回复数
1,862 次查看
Boris_Bloxsberg
Good idea, Thanks man!
1,867 次查看
danielmartynek
1,805 次查看
Boris_Bloxsberg
Hi @danielmartynek ,
I`ve got an addtional question.
What I have to do if I want to change MM9Z1J638 Project to MM9Z1I638 Project?
Is it just a modification of the Linker file (*prm)? Or is there something more?
1,770 次查看
danielmartynek
Hello @Boris_Bloxsberg,
Yes, it is just the linker file.
ROM           = READ_ONLY   0xFE8000 TO 0xFFFDFF; // I
ROM           = READ_ONLY   0xFE0000 TO 0xFFFDFF; // J
1,765 次查看
Boris_Bloxsberg
thx man
