MM9Z1-638: EEPROM access to an illegal address range issue
466 次查看
gumu
Dear Sir,
During recent debugging, it was discovered that there is an "access an illegal address range" issue with the EEPROM. I would like to understand what are the usual reasons that lead to this problem.
MMCEC code is 0x1331。
445 次查看
danielmartynek
Hi @gumu,
What is the content of the MMCPC register?
There should be a value of the PC at the time of the illegal access.
In the disassembly, you should be able to find the fault instruction at the PC address.
MM9Z1-638 has the same MMCV1 module as all the other S12Z MCU where ERR[3:0] = 1 is described as "illegal access" that is specified in the datasheet.
