I have a problem with the printf fonction
1,470件の閲覧回数
Juliendy
I have a problem with the printf fonction.
I'm sorry for my bad english
My program is :
#include <hidef.h>
#include "derivative"
#include <stdio.h>
#include <termio.h>
int x=0;
int main(void)
  for(;:smileywink:
    if(x<20)
      printf("%d\n",x);
      x++;
      return 0;
On HyperTerminal, I don't receive the printf.
I believe that my program is in the loop "while (!(SCI.SCxSR1 & 0x80) )  {};" in the termio.c.  WHY ???
By default, what is the port used, SCI0 or SCI1 ?
How do I configure the connection in hyperterminal, knowing that I have a MC9S12DG128 ?
Best Regards
Julien
764件の閲覧回数
CompilerGuru
The termio.c contains a routine TERMIO_Init for the setup, it might need to be adapted for the hardware.
Alternatively Processor Expert (or Device Initialization) can be used to setup the sci module.
3 返答(返信)
764件の閲覧回数
WadeH
I don't see any harware initialization: somewhere in your code should be a line like:
   Initialize_SCI();
.. or something similar, possibly including a baud-rate setting, parity-type, etc
Look into demo code for your CPU
765件の閲覧回数
CompilerGuru
764件の閲覧回数
Juliendy
thank you for your answer, it's OK for the printf.
The baud rate was bad in TERMIO_Init().
Best Regards
Julien
