How to use log function in S9S12GA240 controller
480件の閲覧回数
punithb
Hi All,
I need to use ln function to read NTC sensor readings. if i use log(number , 2.71828182846) which yields to ln(number). but log function giving wrong value. Could you please tell how to log function in this controller.
419件の閲覧回数
lama
The CodeWarriror IDE  help says:
#include <math.h>
double log (double x);
float logf(float x);
Description
log() computes the natural logarithm of x.
Return
ln(x), if x is greater than zero. If x is smaller then zero, NAN is returned; if it is equal to zero, log() returns negative infinity. In both cases, errno is set to EDOM.
So you should be sure:
  • The function uses correct types.
  • You have included math.h. and you have used correct function logf, log.
  • You have opened project with floating point arithmetics support. (ansib.lib should be visible in the Libs directory in project window)
#include <hidef.h>
#include "derivative.h"
#include <math.h>
int   a;
volatile float y;
void main(void)
  for(;;)
     for ( a=100; a<10000; a+=100)
         y = logf( a );
         asm nop;
A full example project is attached.
Ladislav
