How to  log a data variable using hiwave simulator??
673 次查看
rubykrishna
Actually im using hi wave simulator supported from Codewarrior IDE 5.1. Currently  i need to monitor a variable for a day and log the respective data.
Is there any provision in Hi wave to do tht?? please help!
542 次查看
RadekS
Hi Ruby,
I suppose that you have two basic options:
1.You could implement software routine into you software which will periodically sends variable values trough some channel (like SCI) and use any of serial terminals for logging. This is one of simples method, but it presents additional load for CPU.
Some extension of this principle presents FreeMaster tool.
www.freescale.com/webapp/sps/site/prod_summary.jsp?code=FREEMASTER
2.You could write your own script for hiwave. Unfortunately I have limited experience in that direction. Please look at debugger documentation:
c:\Program Files (x86)\Freescale\CWS12v5.1\Help\PDF\Debugger_HC12.pdf
I could imagine case where you use commands like:
CALL – Executes a command file
DEFINE - Defines a user symbol
LF - Opens a log file
LOG - Enables or disables logging of a specified information type
WHILE - WHILE loop instruction
WAIT - Command file execution pause
DW - Displays memory bytes as words
Note: Example of using command line files are unsecure cmd files in project cmd directory.
I hope it helps you.
RadekS
543 次查看
RadekS
Hi Ruby,
RadekS
