How to include unused rtshc12.c.o (ansixbi.lib) and rtsxgate.cxgate.o (ansi_xgi.lib) functions into object code?
988 次查看
utwig
I am working with a MC9S12XEP100 multiple application image bootloader project. In the future I might want to use more functions from the ansixbi.lib and ansi_xgi.lib libraries. However, my bootloader cannot update that part of the code.
Is there a way to:
1) Force all/part of unused functions of ansixbi.lib and ansi_xgi.lib libraries to be placed in the object code?
OR
2) Place ansixbi.lib and ansi_xgi.lib functions to another segment than the default NON_BANKED segment?
I had similar problems regarding datapage.c, but it was possible to include all of its functions by adding to the prm file:
ENTRIES
     datapage.c.o:*
END
BR,
Timo
635 次查看
ZhangJennie
regarding to your questions:
1. you can add the unused function to ENTRIES section in prm file:
ENTRIES
     function_name
END
2. user need to modify lib source code. Not possible with only lib file.
636 次查看
ZhangJennie
ENTRIES
     function_name
END
635 次查看
utwig
Ah, that's true. I can add every function from the libraries to the ENTRIES.
Thank you!
635 次查看
ZhangJennie
you are welcome!
