Hi :
The exe file downloaded through the following link cannot be linked properly during installation, indicating that the link cannot be found. Could you please provide me with the downloaded code about the 3-Phase Hall Sensor BLDC S12ZVM Application?Note: the chip signal is S12 MagniV MC9S12ZVML128, and the evaluation board is 3-Phase Hall Sensor BLDC S12ZVM Application Using the MTRCKTSBNZVM128 Dev Kit.
Attached is the downloaded exe file。
Best regards:
Asa. Zhai
已解决! 转到解答。
https://www.nxp.com/search?keyword=MTRCKTSBNZVM128_SW&start=0
The first link is correct…
Cancel selection of AMMCLIB installation durin SW installation.
There is a problem with installation and AMMCLIB should be downloaded separately from
roll screen down and select…
Ladislav
Ladislav
