Cann't download software of 3-Phase Hall Sensor BLDC S12ZVM Application
774 次查看
AsaZJP
Hi :
       The exe file downloaded through the following link cannot be linked properly during installation, indicating that the link cannot be found. Could you please provide me with the downloaded code about the 3-Phase Hall Sensor BLDC S12ZVM Application?Note: the chip signal is S12 MagniV MC9S12ZVML128, and the evaluation board is 3-Phase Hall Sensor BLDC S12ZVM Application Using the MTRCKTSBNZVM128 Dev Kit.
      Attached is the downloaded exe file。
Best regards:
Asa. Zhai
755 次查看
lama
https://www.nxp.com/search?keyword=MTRCKTSBNZVM128_SW&start=0
The first link is correct…
Cancel selection of AMMCLIB installation durin SW installation.
There is a problem with installation and AMMCLIB should be downloaded separately from
https://www.nxp.com/design/development-boards/motor-control-development-solutions/automotive-math-an...
roll screen down and select…
Ladislav
713 次查看
AsaZJP
Hi Ladislav:
     Thank you very much
Asa
756 次查看
lama
Ladislav
763 次查看
AsaZJP
Download link below:
https://www.nxp.com/webapp/sps/download/preDownload.jsp
