Are readymade header files available for download from somewhere?
5,412 次查看
pIx
I wanted to use the stdbool.h header file and cannot find it and was wondering if there any any place to download the same that has been compiled for the codewarrior.
Sujith
4 回复数
637 次查看
Lundin
Senior Contributor IV
stdbool.h is C99 specific. Codewarrior does not implement C99.
stdtypes.h is not standard at all.
My advice would be to write your own h-file:
#ifndef _BOOL_H
#define _BOOL_H
typedef unsigned char BOOL;
#define FALSE 0
#define TRUE 1
#endif
Or with typedef enum{FALSE, TRUE}BOOL, but that would be less efficient since enum is likely 16-bit.
637 次查看
imajeff
I looked in my CodeWarrior (8-bit), searching header files for "bool". I found it defined in STDTYPES.H
637 次查看
pIx
Thanks, I have STDTYPES.H :smileyhappy:.
637 次查看
imajeff
They should come with your C compiler (what compiler do you use?)
But here is one I use with GCC
