I think description in the Ref Manual is clear enough. Normally 'Engineering Use POR' signals should be left in default state (all 'ones'), 'General-Purpose POR' can be used by the user as additional configuration signals. It means for example that the user can run boot sequence in different ways depending on the General-Purpose POR value fetched at reset.
Bulat
