where I can find p1020 (e500v2) linux toolchain?
I have downloaded one from here Sourcery G++ Lite 2011.03-38 for Power GNU/Linux but e500v2 is not supported
"error: bad value (e500v2) for -mcpu= switch"
解決済! 解決策の投稿を見る。
ok, I have found solution https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fsourcery.mentor.com%2FGNUToolchain%2F... instead of -mcpu:e500v2 use -te500v2 and it works.
NXP offers prebuild images for this board (kernel, .dtb and root file system).
Thanks for this tip. Do you know if prebuilt binaries are available?
Look at the Section 3.3.7 of NXP SDK 2.9-1703 documentation:
http://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
NPX offers SDK 1.9 for the P1020RDB board.
Use this command sequence for toolchain building and installing under SDK 1.9.
Pavel Chubakov
