Hi :
we are compilation ls1046, But the compilation failed
operating https://community.nxp.com/discussion/?keyword=steps:
1、tar -xzvf flexbuild_lsdk1909_update_221019.tgz
2、cd flexbuild_lsdk1909_update_221019
3、source setup.env
4、flex-builder -h
5、flex-builder -m ls1046ardb -a arm64
Compilation Error:
Building docker_ce ...
cp: cannot stat '/home/join123456/flexbuild_lsdk1909_update_221019/packages/apps/docker_ce/containerd/containerd.io_1.2.4_arm64.deb': No such file or directory
Makefile:753: recipe for target 'docker_ce' failed
make[1]: *** [docker_ce] Error 1
make[1]: Leaving directory '/home/join123456/flexbuild_lsdk1909_update_221019/packages/apps'
Makefile:28: recipe for target 'apps' failed
make: *** [apps] Error 2
make: Leaving directory '/home/join123456/flexbuild_lsdk1909_update_221019'
Please tell me how to do it? Thansk for your support.
Hello join ren,
It seems that docker_ce source wasn't downloaded completely.
Please clean docker_ce build environment with the following command.
$ rm -rf packages/apps/docker_ce/
Then run the following command.
$ flex-builder -c docker_ce -m ls1046ardb
Yiping
Hi Yiping:
Thanks for your reply.
You are right. docker_ce source isn't downloaded completely.
I try to use your suggest. but I cann't download docker_ce package.
Can you tell me why? Please help to provide docker-ce-bin-v18.09.6.tar.gz for me.
Thanks for your support.
Hello join ren,
Probably there is networking problem on your host to download source for docker_ce.
I compressed packages/apps/docker_ce/ folder as a tall, uploaded it in the following link, please deploy it to packages/apps/docker_ce/ on your host PC.
https://drive.google.com/open?id=1Fr7C7gOPOtwZYGenf_1faTIlNH42HYy0
Yiping
Hi Yiping:
Could you upload it to "Baidu cloud disk"?
I can't access this link: https://drive.google.com/open?id=1Fr7C7gOPOtwZYGenf_1faTIlNH42HYy0
Hi Yiping
Thanks for your support. This problem has been resolved.
