USB hub issue enumeration
868件の閲覧回数
fabricedecrop
I'm facing an USB issue, wich does not appear systematically, but leads to no USB devices enumeration.
My plateform is based on P1010, using UTMI and on-chip PHY. I'm using EHCI controller.
P1010 is used in host mode, and is connected to a microchip USB2534 Hub.
My issue is a that the microchip hub is not enumerated at each boot of VxWorks 6.9.4.6.
My problem seems to come from missing SOF. They can be interpreted as a reset by the microchip hub, requested by the host controller. This reset leads to a false enumeration.
Following 3 files, with signal capture, and USB traces.
In good_start.jpg, we see the missing SOF. But is not reconised as reset by the hub. In this case, Hub is enumerated.
In bad_start.jpg, we also so see the missing SOF, but leading to my issue : hub goes to reset state, and then is not enumerated.
In traces.jpg, we see a SOF error packet #70
Could you please help me to solve this issue ? Do you know a workaround in order to have a good enumeration of USB devices at each boot ?
Thanks in advance for your reply,
Fabrice DECROP
3 返答(返信)
687件の閲覧回数
Pavel
The P1010 USB stops SOF generation if RS or RST bits are set in the USB_USBCMD register.
See also the Section 17.7.4.1 of the P1010 Reference Manual.
Pavel Chubakov
687件の閲覧回数
Pavel
The P1010 USB SOF generation can be tested using a timer and polling/interrupt from the USB_USBSTS[SRI] bit setting.
Te USB_USBSTS[FRI[ bit can be used for this task.
See the FRINDEX index.
Pavel Chubakov
687件の閲覧回数
fabricedecrop
I understand that I can check USB SOF generation by this way. But how do I control it, in case of SOF missing ?
Moreover, why are there missing SOF ? Do you confirm that P1010 can miss SOF during enumeration ?
Fabrice DECROP
