This thread from last year indicates it was not supported in 17.06. Has that changed?
The part OVERVIEW page indicates it is supported by LSDK.
In particular, is the PFE (packet forwarding engine) supported in LSDK?
Thanks!
.Tim
Solved! Go to Solution.
NXP SDK 2.0-1703 supports the LS1012a. See SDK 2.0-1703 documentation:
https://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
NXP LSDK 1803 supports the LS1012a. See LSDK 18.03 documentation:
https://www.nxp.com/docs/en/supporting-information/LSDK-KC-REV18.03.pdf
Pavel Chubakov
Pavel Chubakov
Thank you, Pavel.
