We purchased the ls1043a-rgw board.
ls1043a-rgw supports built binaries, but build sources(Yocto) are not available.
We want to build an image by building the source.
The built image will be used with SD card.
Can you provide a guide?
Thank.
NXP offers ASK Loadable binaries for the LS1043ARGW board:
The LS1043ARGW board is not supported in NXP SDK or LSDK. Change the LS1043a u-boot configuration for the LS1043ARGW board. See attached files.
Pavel Chubakov
