Hi Team,
We were porting our changes on the qoriq, we have application & script dependency with the interface name eth*( eth0 etc). But in current case its interface name coming as fm1-mac*(fm1-mac6) .
So how we can keep the interface name same as eth*(eth0) .
I can see the serial logs it is renamed while bootup:
[ 4.177233] lm90 1-004c: Dropping the link to regulator.0
[ 4.213369] fsl_dpa soc:fsl,dpaa:ethernet@5 fm1-mac6: renamed from eth0
[ 4.251137] fsl_dpa soc:fsl,dpaa:ethernet@9 fm1-mac10: renamed from eth2
[ 4.283422] fsl_dpa soc:fsl,dpaa:ethernet@8 fm1-mac9: renamed from eth1
Prafull
