Hi Thank you always...
I uses lx2160ardb.
According to 'LSDKUG_Rev19.09.pdf' 5.4.4.1, mc.itb image can be update using u-boot cli.
I want to update that image after linux kernel booting. How can i do?
Songhee
已解决! 转到解答。
If you use SD card boot, you could use the following command to write MC image under Linux
$ sudo dd if=mc.itb of=/dev/sdX bs=512 seek=20480
Note:/dev/sdX is SD card device name.
