GPIO initialisation
GPIO initialisation
697件の閲覧回数
ebyjayan
This is with regarding to processor P2040.
Is it possible to make any GPIO accessible at PBL stage only, that is, we can toggle the GPIO when we are at PBL booting stage and after PBL stage no one can access that GPIO.
Also, NOR (GPCM) doesn't has any dedicated Write protect signal, which GPIO can be used to achieve this (write protect) functionality.
3 返答(返信)
601件の閲覧回数
ufedor
This is not possible at the processor level. Possible solution is to implement an external gate for a GPIO signal.
It is up to the designer which GPIO signal to use for implementing required functionality.
600件の閲覧回数
ebyjayan
Hi Fedor,
Thanks for your clarification on the GPIO accessibility. I would like to add one more point in the above discussion that we have LGTA signal in GPCM which terminates the external access to the NOR. Can we use this signal as write protect?
601件の閲覧回数
ufedor
The LGTA_B can't be used as write protect at least because it is input.
