Cannot build tsntool with flex builder on ubuntu20.04
HingWong
When I compiled tsntool with flex builder on ubuntu20.04, Found an error unable to access "https://source.codeaurora.org/external/qoriq/qoriq-components/tsntool.git/", I read another post that source.codeaurora.org is out of service, so is there any way to compile tsntool now?
hingw@ubuntu:~/ls1028/flexbuild_lsdk2108$ flex-builder -c tsntool
COMPONENT: tsntool
make: Entering directory '/home/hingw/ls1028/flexbuild_lsdk2108'
make[1]: Entering directory '/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps'
 Building tsntool ...
Cloning into '/home/hingw/ls1028/flexbuild_lsdk2108/components/apps/networking/tsntool'...
fatal: unable to access 'https://source.codeaurora.org/external/qoriq/qoriq-components/tsntool.git/': Could not resolve host: source.codeaurora.org
make[1]: *** [/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps/networking/tsntool.mk:11: tsntool] Error 128
make[1]: Leaving directory '/home/hingw/ls1028/flexbuild_lsdk2108/packages/apps'
make: *** [Makefile:25: tsntool] Error 2
make: Leaving directory '/home/hingw/ls1028/flexbuild_lsdk2108'
In addition, I see the tsntool source package on github, the compiler instructions to specify a kernal source path, this path should be filled with what?
1. Libraries requirement
   Libraries libnl-3.0, libtermcap, libreadline libcjson are needed.
2. How to compile the tsntool:
2.1 Setup cross compile environment
2.2 Compile binary:
    > source source_arm64.sh <dir_to_kernel_source>
    > make
    The tsntool and libtsn.so will be generated.
khushbur
Hi @HingWong
LSDK source has been moved from from Code Aurora to GitHub. Please download latest lsdk from below link and build your image.
https://nxp.flexnetoperations.com/control/frse/product?entitlementId=677519487&lineNum=1&authContact...
Khushbu
HingWong
Thanks for your reply! When I click this link, it does not take me to the download page, but to my profile page. It seems like I have no permission to download this LSDK, do I need to apply for NDK?
khushbur
Hi  @HingWong
Please go to below link and click on Download. Login with your credential and you will be able to download LSDK 21.
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/layerscap...
Khushbu
HingWong
The problem is with LSDK 2108, please refer to the log I sent earlier. When using
to build tsntool, it still tries to clone the code from source.codeaurora.org. Is the URL in the compilation script not updated?
thanks!
khushbur
Hi @HingWong
In flexbuild_lsdk2108/configs/sdk.yml file
replace “source.codeaurora.org/external/qoriq/qoriq-components”
with “github.com/nxp-qoriq”
for example for tsntool
would become
https://github.com/nxp-qoriq/tsntool.git
Khushbu
HingWong
Hi @khushbur
Thanks for your support, the problem has been resolved after replacing the URL.
