Bootargs for NAND Flash
1,540件の閲覧回数
varada_pavani
Hi ,
We are using LS2088A Based custom board. We are booting PBL and U-boot from QSPI Flash and we want to boot dpl, dpc, dtb, kernel and filesystem  from NAND flash. So can anyone suggest proper bootargs for this.
Thanks.
3 返答(返信)
1,279件の閲覧回数
Pavel
It looks like that your command "bootm" is incorrect
See the page 148 of LSDK 19.03 documentation.
=> bootm a0000000#<board-name>
The <board-name> can be: ls1012ardb, ls1012afrwy, ls1043ardb, ls1046ardb, ls1088ardb, ls2088ardb.
Pavel Chubakov
This thread is continued as a private discussion with the submitter,
NXP support is not following the thread anymore.
1,279件の閲覧回数
Pavel
Look at the Section 7.2.6.2 of LSDK 19.03 documentation:
https://www.nxp.com/docs/en/user-guide/LSDKUG_Rev19.03.pdf
Create .itb file.
Write this file to the NAND.
Use "nand read" command for reading .itb file to the SDRAM.
Use "bootm" command for booting.
Pavel Chubakov
1,279件の閲覧回数
varada_pavani
Hi Pavel Chubakov,
We have created lsdk_linux_arm64_tiny.itb file using  this command flex-builder -i mklinux -m ls2088ardb -a arm64 and flashed using following procedure.
fatload mmc 0 0xa0000000 lsdk_linux_arm64_tiny.itb
nand write 0xa0000000 0x0 $filesize
nand read 0xa0000000 0x0 $filesize
=> bootm 0xa0000000
## Loading kernel from FIT Image at 80000000 ...
Could not find configuration node
ERROR: can't get kernel image!
Getting above error. Can you please help us?
