Issues for FreeMASTER PE Component in MQX_IO Interface
1,082 次查看
chiasyan
There are several issues found when generating code using PE's FreeMASTER component in CW10.3:
  1. #define FMSTR_USE_MQX_IO  1 : This line of code isn't generated in "freemaster_cfggen.h".
  2. There is NO installation of MQX IO driver in static FMSTR_BOOL FMSTR_InitMQX(void) function, under "freemaster_serial.c". The channel is opened directly, causing unidentified directive error during build (eg. ittyc:).
  3. The channel generated under #define FMSTR_MQX_IO_CHANNEL ittyc: isn't enclosed by double-quote (" ").
Thank you.
734 次查看
JardaP
Hello Chiasyan,
I can confirm this behavior, Im sorry for this bug.
You can write missing configuration into "freemaster_cfg.h". This file is generated once, when FreeMASTER component is included into project.
This will be fixed in next Processor Expert release.
Jaroslav
734 次查看
JardaP
Hello Chiasyan,
The update of FreeMASTER component is here:
https://community.freescale.com/docs/DOC-95086
Jaroslav
