Dear NXP support,
Do you have any sample code for CAN RTR messaging, on the receiver side (the one that receives the message and issues the response)?
I'd like to know:
1) if the buffer has to be filled every time, after the response is issued.
2) if there is any restriction on filling the buffer (as I've seen in other microcontrollers that a double response could be issued when filling the buffer while the RTR frame is received).
#s32k144
Thank you,
Javier Rico
解決済! 解決策の投稿を見る。
Hi Francisco,
yes, this could be an option if you do not want to have automatic response.
BR, Petr
Thanks Petr,
It is still not clear to me how the mailbox can be filled without the risk of the CAN RTR message being received in the middle of this process, resulting in sending a response that is incomplete or mixing old and new data in the same message. Any advice?
Javier
updating the MB with new data should be done when MB is inactive. So if you inactive used MB and it is done before content moving-out into SMB, then no response will be send. If inactivation is done after message is in Tx SMB, then response will be transmitted, but you will not see double response.
BR, Petr
Hi Francisco,
BR, Petr
per my understanding, the FLEXCAN_DRV_ConfigRemoteResponseMb function can be used to prepare MB for remote request response. This need to be called just once, you need not to config MB every time.
No restriction should be there.
BR, Petr
