UPM values update
UPM values update
6,237件の閲覧回数
m_syed_ahmed
We are working on the MPC8248 custom board. We have different timing valued SRAM chips. How to update the timing values for UPM devices? How does the UPM values obtained?
タグ(2)
8 返答(返信)
6,148件の閲覧回数
yipingwang
Please refer to "11.6.2 Programming the UPMs" in https://www.nxp.com.cn/docs/en/reference-manual/MPC8272RM.pdf.
5,929件の閲覧回数
m_syed_ahmed
Is it possible to re-configure the UPM values at kernel level?
5,863件の閲覧回数
yipingwang
Please refer to the following files in the BSP.
arch/powerpc/sysdev/fsl_upm.c
include/asm-powerpc/fsl_upm.h
5,859件の閲覧回数
m_syed_ahmed
Am not able to find that file.  Can you tell in which kernel version those files were available? Also, we are working on 2.6.20. Is it possible to port those files to this version?
5,842件の閲覧回数
yipingwang
Please refer to the following.
./drivers/mtd/nand/fsl_upm.c
5,840件の閲覧回数
m_syed_ahmed
My kernel 2.6.20 doesn't have that file too. But I found that in the latest kernels. Is it possible to port that file to 2.6.20?
5,720件の閲覧回数
yipingwang
Please try to back port that driver file in your Linux Kernel.
5,720件の閲覧回数
yipingwang
