UCC uart on MPC8321
UCC uart on MPC8321
748 次查看
marcbalemboy
     On a MPC8321, i'm trying to get UCC5 to work in uart mode (with linux).
     When i try to send a message, Tx pin is activated (high) but never actually transmit data, ready bit never go down.
     CTS is high, but pio is configured as GPIO, so it shouldn't matter, right ?
     In loopback mode (GUMR_L[DIAG] = 0x01), it doesn't seem to get any better.
     The following configuration is used in dts :
ucc5pio:ucc_pin@05 {
                                pio-map = <
                                        2    0    1      0    2    0  /* TxD5 */
                                        2    8    2      0    2    0  /* RxD5 */
                                        2   29    2      0    0    0  /* CTS5 */
                                        2   31    1      0    0    0  /* RTS5 */
ucc@2400 {
                        device_type = "serial";
                        compatible = "ucc_uart";
                        cell-index = <5>;       /* The UCC number, 1-7*/
                        port-number = <0>;      /* Which ttyQEx device */
                        //soft-uart;            /* We need Soft-UART */
                        reg = <0x2400 0x200>;
                        interrupts = <40>;      /* From Table 18-12 */
                        interrupt-parent = < &qeic >;
                         * For Soft-UART, we need to set TX to 1X, which
                         * means specifying separate clock sources.
                        rx-clock-name = "brg6";
                        tx-clock-name = "brg5";
                        pio-handle = < &ucc5pio >;
               Is there something i'm missing out ?
regards
511 次查看
marcbalemboy
Well my problem is still not resolved.
I've tried using UCC3 in loopback mode, but i hang at the same point, ready bit never go down.
Checking set up of the driver, I've noticed that programming sequence with soft-uart patch does not follow  what's described in SOFTUARTUCODERN_0_1_2.pdf (Table 0-6) :
0x94 SoftUART_RxState          Word         QE internal,           initialize to 0x04
0x9D SoftUART_RxBitmark      Byte           QE internal,          initialize to 0x7
both are initialized to 0 in linux drivers (ucc_uart.c line 722).
Is this a mistake or is there some other document provinding instruction for using soft_uart microcode  that I've missed ?
regards,
Marc
