Linux Driver for QE UMCC
974件の閲覧回数
aleksandargeras
We are currently working on a product based on T1040, and we are planning to use QE UMCC for implementing TDM link.
We are estimating needed effort for implementing this in Linux Kernel, so far we have seen that there is no available UMCC driver.
So our question is:
Is there currently publicly available Linux Kernel driver that uses UMCC functionality, or is there a plan in near future such a driver to be available?
Aleksandar
3 返答(返信)
698件の閲覧回数
tedfriedl
Aleksandar,
How did you do with this project?  I'm doing the same now for VxWorks. I think I have most of the UMCC/SI/TDM figured out for my application except for the commands to the UMCC through the CECR register.  NXP's discussion about this in the Rev 8 QEIWRM is sparse and seems contradictory.
Ted Friedl
698件の閲覧回数
Pavel
Use SDK 2.0 for the T1040 board. Look at kernel menu configuration from this SDK.
Device Drivers  --->
[*] Wan interfaces support  --->
<*>   Generic HDLC layer
<*>     Freescale QUICC Engine HDLC support
Pavel Chubakov
698件の閲覧回数
aleksandargeras
Hi Pavel,
Thanks for your answer, we are aware of fsl_ucc_hdlc driver, the question is not regarding ucc hdlc driver.
We are planning to use umcc (replacement for mcc in T1040 QuiccEngine) for implementing 8 independent 2Mbps
TDM lines using UMCC and one of the available TDMs (TDMA or TDMB).
Current kernel QE support (drivers/soc/fsl/qe) already provides interface (examples) for configuring some of the QE subsystems (UCC slow, tdm, muram, also there is ucc_uart driver avilable) but there is no interface (example) for using UMCC.
So this specific question is related exactly to UMCC usage and current Kernel support availability.
It would be of help if any kind of PoC kernel driver, or configuration example in any other form is available beside
what is described in QE documentation.
Aleksandar
