I am using IMX8MM, Linux Yocto & Small RT RTOS Application under M4.
After testing sleep mode, i need the option to leave M4 Application up and running.
1. What is the procedure and setting at device-tree ?
2. Is there a commands for linux ?
3. Leave the Uart periphery under M4 Application works.
Eyal
The following article will increase your knowledge regarding Hr Express Kroger. We will also discuss on Express Hr Kroger Login
i.MX8M MINI can support the function you describe.
For example, you can evaluate and test 'sai_low_power_audio' in M4 SDK :
Hope the information is helpful to you.
Have nice day!
B.R,
weidong
