Dear NXP Supporter:
Where can i find the value of PF8200: RθJC(top) Junction-to-case (top) thermal resistance, porter:
the Datasheet just show R θJC: Junction to Case (bottom) value, thermal simulation need this value:
Where can i look up the RθJC(top) Junction-to-case (top) thermal resistance, or provide such as: 2R、delphi, Detailed thermal resistance model, (Preferred Flotherm software model ,or Icepak software are also available). thank you~!
Solved! Go to Solution.
Dear Jooph,
Please find attached the Flotherm thermal model.
Hope it helps!
Tomas
Dear Jooph,
Hope it helps!
Tomas
Dear Tomas:
Very helpful, Thank you very much for you support~~!
