FS26xx: BATSENSE pin
1,561 次查看
CarlosOrendain
In FS26xx, Is BATSENSE used for any other purpose than AMUX?
1,485 次查看
guoweisun
The Fail-safe machine is powered by VSUP, with a redundant supply connection
available through VSENSE.
5 回复数
1,552 次查看
guoweisun
This pin is for Battery sense terminal and Connection mandatory.
1,523 次查看
CarlosOrendain
What will happen if this pin is open? or if it is shorted to GND?
1,508 次查看
guoweisun
The safety function will be effected.
1,501 次查看
CarlosOrendain
It is going to assert the FS0b pin?
1,486 次查看
guoweisun
