FS26 deinit
FS26 deinit
833件の閲覧回数
YBoughallad
I wanted to ask if there is a proper/safe way to deinit the FS26.
my use case is :
i get the FS into normal mode in the Bootloader software. But if I jump to the application, I cannot reinitialize it again as it is already in Normal mode. I want to set the FS26 back to init FS state and maybe disable the watchdog until it get initialized again in the Application.
is this possible? if not, is there a recommended procedure for this case?
YBoughallad
4 返答(返信)
824件の閲覧回数
ErikaC
Yes, that is possible with an SPI command called GOTO_INIT in FS_SAFE_IOS_1 register
Regards.
793件の閲覧回数
YBoughallad
thank you for your response.
is this the only thing I need to do? how about the watchdog, will it be disabled until I initialize again the SBC?
YBoughallad
600件の閲覧回数
cuongnguyenvan
A little bit support,
In the BOOT,
INit with disabled watchdog duration.
Jump to APP
Goto InitFS again by write GOTO_INIT bit
Initialize FS26 again within 256 ms after you switched back InitFS state.
787件の閲覧回数
ErikaC
