Using Watchdog Interrupt with MPIC in P4080
954件の閲覧回数
clemensreibetan
I still struggle to get a watchdog interrupt in P4080.
I want to signal to Core0 that Core4 got a watchdog timeout. I think this is possible with the MPIC.
These are the relevant setting on Core4:
TCR=0x98120000
MSR=0x2a000
MPIC_IILR1=0x0
MPIC_IIVPR1=0x88000c
MPIC_IIDR1=0x1
But when an interrupt occurs, this is what I get
Core4: MPIC_WSRSR0=0x0
Core4: TSR=0xf0000000
Core4: InterruptHandler: 0xb00 exception.
What I expected was that there is something in the MPIC_WSRSR0.
I also set EDBCR0[EDM] to 0, thanks to lunminliang, but this also didn't help.
The manual (P4080RM p. 340)
The platform indicates to the MPIC that a core watchdog timer event has occurred by
updating the core’s associated field (WRSn) in the MPIC's Watchdog Status Register
Summary Register (WSRSR).
So what else do I need to do so the WSRSR is updated?
Thanks for the help so far.
タグ(4)
3 返答(返信)
610件の閲覧回数
lunminliang
I thinks two things need to make clear:
1.  "Core4: InterruptHandler: 0xb00 exception."
    >>Make sure if this is Watchdog? If there is any interrupt on Core0?
2.  "But when an interrupt occurs, this is what I get
    Core4: TSR=0xf0000000"
    >>Do you get before or after the interrupt execution?
Lunmin
610件の閲覧回数
scottwood
The watchdog expirations come in phases.  On the first expiration, TSR[ENW] is set and no interrupt happens.  On the second, TSR[WIS] is set, and a watchdog exception (not the MPIC interrupt) happens if TCR[WIE] is set.  On the third expiration, the action in TCR[WRC] takes place (in your case, causing an MPIC interrupt).
Since you have TSR[WIS] set, you will get that exception one watchdog period before the MPIC interrupt.  I'm guessing that "0xb00 exception" is the watchdog exception but I don't know how you've programmed that IVOR.
610件の閲覧回数
clemensreibetan
Yes indeed that was my problem. I thought it would set the MPIC interrupt when the interrupt in the core is set.
Now I just disabled the interrupt (TCR[WIE]=0) and it kinda works.
Now I get the external interrupt on the other core exatctly 1 time.
I handle this with this routine:
// read IACK
value = *((unsigned long *)(0xFE000000 + 0x400A0));
// clear Watchdog status register
*((unsigned long *)(0xFE000000 + 0x43A00)) = 0x100;//3 << 8;
//disable external interrupt
asm("wrtee %0" : : "r" (0));
// clear EOI
*((unsigned long *)(0xFE000000 + 0x400B0)) = 0;
// check EOI
value = *((unsigned long *)(0xFE000000 + 0x400B0));
if (value)
     printf("Core0: EOI=0x%x\n\r", value);
// reenable external interrupts
asm("wrtee %0" : : "r" (1));
After this I reset the TSR to 0x0 and wait till it is 0xd0000000 (Watchdog expired for the 3rd time). But now the MPIC_WSRSR0 is not set anymore.
Why not? (I am using the mixed mode of the MPIC)
Hope you can help me with this.
Thanks for the help up to now.
