The P2020 SGMII signal has fixed rate in according to the SGMII specification. To support 10 Mbps and 100 Mbps data rates, SGMII stretches the frame by replicating each frame byte 10 times for 100 Mbps and 100 times for 10 Mbps
It will not look like 62.5 mhz or 6.25 mhz data on the line. The SGMII signal has fixed bit rate.
