tagWriter Looping Write Error
clintongallaghe
// August 28th, 2022
// Device: Google Pixel 4A Android 12 --and-- Android 13
// TagWriter Version: 4.8.7
// TapLinx SDK Version: 1.9
Endless looping write failure when trying to use TagWriter to write to a blank NXP NTAG216 Type 2 Tag. I then used another app on the device to write and store a URL on that tag I am using to attempt using TagWriter to write over and/or erase; both functions of which continue to fail as noted...
tagWriter step1 geocode.png => save and write
tagWriter step2 geocode.png => write
tagWriter step3 geocode.png => tap tag as instructed
tagWriter step2 geocode.png => step3 reverts to this step2 after tag is tapped as instructed
tagWriter step4 stops.png => stop error message after => write on step2.png after being reverted back to step2.png as instructed by step3.png
NOTE: the same failure loop occurs when attempting to encode a URL data type. The Erase function has also stopped and loops. Read function and such remain functional.
NOTE: TagInfo functions as expected
Fabian_R
Hello sir,
Thank you for writing to us
If you could please check this with another phone. I was able to reproduce this with your data, by using a Pixel 3 and a Samsung A53. Could be possible that there might be an external issue? Maybe the tag is producing this error or another application on the phone?
Please let me know your findings.
Fabian
