mifare desfire ev1 api for pn7160
935件の閲覧回数
erikchuro
Hi!
I installed the libnfc-nci on a rasbperry pi 3. I read Mifare Classic card but Desfire ev1 doesn´t. The main.c file of the nfcDemoApp only support mifare classic and mifare ul technologies.
else if(TARGET_TYPE_MIFARE_CLASSIC == TagInfo.technology){ ... }
else if(TARGET_TYPE_MIFARE_UL == TagInfo.technology) { ... }
There any example code to read Mifare Desfire ev1. I want to
  1. authenticate on Mifare Desfire
  2. select an application
  3. Authentication with NDEF Tag Application master
  4. read data.
Thanks.
タグ(1)
5 返答(返信)
775件の閲覧回数
erikchuro
Thanks.
I can know access to secure files ( Secure Files (nxp.com) ) but i can´t find out any example code of sw6856. I don´t know if i need more grants.
751件の閲覧回数
danielchen
yes, you need to apply the access rights for the documents you want.
905件の閲覧回数
danielchen
Hi @erikchuro
I would suggest you refer to sw6856 --LINUX libnfc-nci MIFARE examples.
please kindly note that MIFARE products are secured with NDA (Non-Disclousre-Agreement).  you need to sign NDA with NXP to get it.
875件の閲覧回数
erikchuro
Thank you.
I apply for a NDA. I received the ticket from your platform but when i want to see the details on the NXP technical support portal using the received link, the page is invalid. Zero cases are listed under the Case portal ( https://support.nxp.com/s/cases ) . Am I doing something ?
818件の閲覧回数
danielchen
Hi Erik:
If you have problems to check the cases, you can live chat to NXP .
https://www.nxp.com/support/support:SUPPORTHOME?tid=sbmenu
