lv_group_t* group = lv_group_create();
lv_group_add_obj(group, ui->Parameters_list_1_item0);
lv_group_add_obj(group, ui->Parameters_list_1_item1);
lv_indev_set_group(keypadIndevice, group);
lv_group_focus_obj(ui->Parameters_list_1_item1);
lv_group_focus_obj(); Set the focus, the control has no response, which is successful in some interfaces
Hello @qqt_996
could you please share the NXP part/device you are using to be able to redirect your query properly?
Thank you
Kind regards
Hello @qqt_996
Could you please also share which NXP part number you are using?
Thank you in advance.
