I want to add a node in the VPP framework that will directly send Ethernet packets to the application.
You can check the Vpp implementation:
https://community.nxp.com/t5/Layerscape-Knowledge-Base/Vector-Packet-Processing-VPP-IPSEC-Implementa...
thanks for answer. i have another question , how to config vpp to cross compiling?
