Ok Fabio Estevam, But i didnt understand.You are telling this?if yes please tell me how to you. I am newbie Unsigned Integer64. Range: 0 - -1 Default: 0 Current: 0
fullscreen : If true it will be Full screen
flags: readable, writable
Boolean. Default: false Current: false
disp-width : gets the width of the image to be displayed
Integer. Range: 0 - 2147483647 Default: 0 Current: 0
disp-height : gets the height of the image to be displayed
axis-top : gets the top co-ordinate of the origin of display
axis-left : gets the left co-ordinate of the origin of display
rotate : gets the angle at which display is to be rotated
crop-left-by-pixel : set the input image cropping in the left (width)
crop-right-by-pixel : set the input image cropping in the right (width)
crop-top-by-pixel : set the input image cropping in the top (height)
crop-bottom-by-pixel: set the input image cropping in the bottom (height)
fullscreen-width : gets the full screen width of the display
Integer. Range: 0 - 2147483647 Default: 0 Current: 240
fullscreen-height : gets the full screen height of the display
Integer. Range: 0 - 2147483647 Default: 0 Current: 320 see when i use this width and height command,but its saying error root@freescale ~$ gst-launch filesrc location=/root/yuvraj.mp4 ! mfw_mp4demuxer
! queue max-size-time=0 ! mfw_vpudecoder ! mfw_v4lsink fullscreen=true fullscree
n-width 400 fullscreen-height=800
MPEG4PARSER_05.14.00 build on Aug 6 2009 13:54:26.
MFW_GST_MP4_PARSER_PLUGIN V1.6.0-r1 build on Jan 6 2010 16:52:33.
MFW_GST_V4LSINK_PLUGIN V1.6.0-r1 build on Jan 6 2010 16:52:40.
WARNING: erroneous pipeline: no element "fullscreen-width"
root@freescale ~$ please help me
