What should be the wattage of 60.4ohm CAN TJA1463 transceiver termination resistor?
Please share the details
Solved! Go to Solution.
Our AH2002 provides guidelines regarding the termination resistors in chapter 7.4.
However, we do not have any specific recommendations for wattage calculation, I would recommend you to follow general guidelines keeping in mind the maximum short circuit current of 125mA.
BR, Tomas
Short circuit current means, with 12V or 24V, Please provide more detailed understanding on short circuit current
Either 12V or 24V depending on your application/VBAT voltage.
BR, Tomas
BR, Tomas
