Using a MOSFET as a switch to connect circuit to ground or high impedance
866 次查看
kmeier
I am looking for a switch with sub-nanosecond switching times (just under a nanosecond) that connects a low-pass RC filter to either ground (for discharging) or high impedance (allowing the filter to have normal operation). Will a MOSFET do this? It's basically a controlled SPST switch to ground.
I am specifically looking at NXP's BF1108 MOSFET: http://cache.nxp.com/documents/data_sheet/BF1108_BF1108R.pdf?pspll=1.
I would like to simulate it in SPICE, but it seems this datasheet is not as comprehensive as other MOSFET datasheets and there is unfortunately no model. I am using this with a single-photon detector so it is low power and small signal; the drain voltage would be around 800 mV .
  • RF
0 回复数
