Temperature Cycling (TC) use ic or pcb?
jingfang
NXP through the automotive grade certification products,Temperature Cycling use IC or PCB?
guoweisun
This should be reliability test which test in PCB mounted the IC according the request of JESD22.
guoweisun
jingfang
The guest is asking if there is documentation?
