Is TagXplorer compatible with ACS ACR122V-A9 reader/writer?
If so, can this combination be used to write some NTAG 424 DNA chips?
Finally, to do this in TagXplorer, should I use the NDEF Operations or the NTAG Operations?
The supported contactless Reader supported includes:
ACR122V-A9 is not in the list.
uTrust 3700 and 4701 don't seem to work.
Hi @danielchen , thank you for your answer.
Could you please also indicate which devices are compatible with the RFIDDiscover program?
Is this software, in its lite version, useful to write NTAG 424 DNA tags?
Esteban
You can see the differences between Lite version and full version.
