We are using 5G CV2X Evaluation module.
We want to use an external HSM which is NXP SXF 1800.
For this we have to deploy V2XCrypto Library and V2X Crypto API of this module.
We know that this must be done by creating a recipe file for yocto. Can you help us create this file?
Solved! Go to Solution.
Hope you are doing well. I'm sorry for the inconveniences this may cause, but, unfortunately, information about the SXF and other V2X Automotive Products is protected under a Non-Disclosure Agreement.
To obtain information about these products, could you please contact your Local Distributor from the Distributor Network so they can not only help you with the NDA process but also provide you the information you might need of those products?
Ricardo
Ricardo
