SGTL5000, overvoltage
UweA
Does the SGTL5000 have an internal protection against overvoltage for its line in- and outputs? (e.g. with Z-Diodes?)
Uwe
Guofred
Hi Uwe,
Reviewing the application diagram, i haven't  found any internal protection circuit for the input voltage , if you concern this issue, may be we can add some external protect circuit to the SGTL5000,thanks.
Best regards.
Guofred
UweA
Hello Tomas,
do you know what the max. voltage is?
Uwe
TomasVaverka
Hello Uwe,
The maximum voltage can be found in the datasheet, Tables 2 and 4.
Tomas
TomasVaverka
Hello Uwe,
The SGTL500 does not have such a protection.
Tomas
