SE050 no response after consecutive writes
vchundi
Thank you for your support. we are testing SE050 low level functionality, we have created the write failure and we would like to understand, how to recover SE050 without performing hard (cold) reset.
Log Start:
I2C Init Operation
       App:DEBUG:I2C_Config_Init Speed = 0x186A0
       App:DEBUG:axI2CInit I2C Clk 100000
Write Interface Reset Req Command
       App:DEBUG:axI2CWrite Slave Address 0x90  Address 0x90
       App:DEBUG:axI2CWrite txLen = 0x05
       App:INFO :axI2CWrite (Len=5)
                              5A CF 00 37        7F
       App:DEBUG:axI2CWrite retStatus = 0x0C I2CHAL Status = 0x00
       App:DEBUG:axI2CRead Slave Address 0x90  Address 0x90
       App:DEBUG:axI2CRead = 0x03
       App:INFO :axI2CRead (Len=3)
                              A5 EF 23
       App:DEBUG:axI2CRead retStatus = 0x0C I2CHAL Status = 0x00
       App:DEBUG:axI2CRead = 0x25
       App:INFO :axI2CRead (Len=37)
                              00 A0 00 00        03 96 04 03        E8 00 FE 02         0B 03 E8 08
                              01 00 00 00        00 64 00 00        0A 4A 43 4F        50 34 20 41
                              54 50 4F 87         77
Write Get ATR Command
                              5A C7 00 F7        B1
                              A5 E7 23
                              54 50 4F 2A        8D
Create Write Failure
Write Get ATR Req Command
                              5A C7 00 F7        B1
                              5A CF 00 37        7F
Write SE Reset Req Command
                              5A C6 00 2F        A8
       App:DEBUG:axI2CWrite retStatus = 0x0F I2CHAL Status = 0x01
Dummy Read Operation : Recovery
       App:DEBUG:axI2CRead = 0x0F
       App:DEBUG:axI2CRead retStatus = 0x0E I2CHAL Status = 0x01
I2C Init Operation
       App:DEBUG:I2C_Config_Init Speed = 0xF4240
       App:DEBUG:axI2CInit I2C Clk 1000000
                              5A CF 00 37        7F
                              5A C7 00 F7        B1
                              5A C7 00 F7        B1
                              5A CF 00 37        7F
                              5A C6 00 2F        A8
