SC16IS752IBS
SC16IS752IBS
640 次查看
Kiwon
Hello
With 2.5V power input, the "RXB" Pin measures +1.4 to 1.6V.
I would like to ask you to check the cause. (Please explain the chip internal configuration circuit, etc.)
6 回复数
622 次查看
Kiwon
Do you mean when VCC 2.5V get RXB 1.4V? right?
   => Yes
does this IC works normally?
    => Yes, It works without any problem. We do Tx/Rx Low/High Level Check inputting I2C CMD
Question
We’d like to check the reason that the default 1.4 in “RXB” is measured when we give 2.5v without turning up the UART PGM.
Is there pull-up circuit in “RXB” pin in UART? can you provide the detailed circuit or explanation please?
We’re asking it since our customer worries that this voltage can cause the damage in their device which is connected to “RXB” on the test board.
610 次查看
guoweisun
Could you please fill  below:
1: company name /location
2: project volume
3: volume/annual
600 次查看
Kiwon
TSE Co., Ltd. (South Korea)
we used it about 5K last year. Can we have the technical help or the direct contact e-mail/number please?
597 次查看
guoweisun
For the IC internal circuit review I need escalated to design/app team for help, so need your detail information:
1: company name/location
2: project schedule
3: volume/annual
584 次查看
Kiwon
I already answered in nabove.
1: company name/location : TSE Co., Ltd. / South Korea
2: project schedule: The test boards using SC16IS752IBS are provided to the customer and the issue found during the test. it is urgent..
3: volume/annual : Usually 5K ~8K anually.
638 次查看
guoweisun
Do you mean when VCC 2.5V get RXB 1.4V?right?
