QN9090DK Peripherals tool
woookk123
I have a QN9090DK board.
I want to configure configuration settings such as uart speed setting and i2c speed setting in Peripherals tool, but an error appears.
The error is "Peripherals tool does not support selected processor. Select different tool."
I think my board will support the Peripherals tool, but for some reason it doesn't seem to work.
help.
thank you
SDK: SDK_2.x_QN9090DK6
version: 2.6.5
Gavin_Jia
Hi @woookk123 ,
Thanks for contacting NXP support.
I have tried following your operation here. According to the information provided by the "config tool overview", the current processor does not provide automatic modification of "Peripherals, TEE, Device Configuration". If you need, you can only modify it manually in the code.
Sorry for any inconvenience.
B.R.
Gavin
